My triggers and nodes do not return results when pressing execute until I stop, but the Executions tab still reports successful execution and returns results. Please refer to my screen record:
Video: Video Unavailable
n8n version: 1.23.0
Database (default: SQLite): SQLite
n8n EXECUTIONS_PROCESS setting (default: own, main): own
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
I suspect there could be an issue in the configuration as I am not able to reproduce this, Are you using something like Cloudflare in front of n8n or maybe a reverse proxy that doesn’t have websockets enabled?
Your nginx configuration is not configured to use websockets correctly which will cause some issues. I would start by updating your location to be something like the below which has worked for other users.
