No, the only error I get when enabling SSL if that the connection cannot be establish, since I’m not configuring the connection with the certificate because I don’t see any options to do it so (maybe editing the expression?).
that error is showing up because of the SASL mechanism not being defined in the Kafka credentials. I’ve opened this PR that solves the issue. would you be able to test it and confirm?
