Not able to create an organization in Pipedrive with custom properties
I’m trying to create an organization in Pipedrive with some customer properties, just like it works with a Deal or a Person. However, the only difference is that whenever I add a custom property, there are no dropdown options but rather a text field. And the flow stops since on this step with an error
"name": "NodeApiError",
"cause": {
"message": "400 - {"success":false,"error":"Invalid field(s) in the payload: Website, LinkedIn","error_info":"Please check developers.pipedrive.com for more information about Pipedrive API.","data":null,"additional_data":null}",
"name": "Error",
"stack": "Error: Request failed with status code 400 at createError (/data/node_modules/axios/lib/core/createError.js:16:15) at settle (/data/node_modules/axios/lib/core/settle.js:17:12) at IncomingMessage.handleStreamEnd (/data/node_modules/axios/lib/adapters/http.js:269:11) at IncomingMessage.emit (node:events:538:35) at endReadableNT (node:internal/streams/readable:1345:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)"
"node": {
"parameters": {
"authentication": "apiToken",
"resource": "organization",
"operation": "create",
"name": "={{$node["Webhook"].json["body"]["current_company"]}}",
"additionalFields": {...} // 1 keys
"name": "Pipedrive",
"type": "n8n-nodes-base.pipedrive",
"typeVersion": 1,
"position": [
1460,
460
"alwaysOutputData": true,
"credentials": {
"pipedriveApi": {...} // 2 keys
"timestamp": 1650624769787,
"message": "Bad request - please check your parameters",
"httpCode": "400",
"description": "Invalid field(s) in the payload: Website, LinkedIn"
Hey @Artego, I hope you’re well?
Have you seen this post on the topic? Might be worth giving this a go and see if your custom fields can be written if you use the internal ID of the field.
Geez. Pipedrive is always troublesome. Thank you for your help
Go to Company Settings > Data Fields, then select the Person tab. Check the Custom Fields dropdown for your custom field. Click the three dots in the right corner of the field, then select Copy API Key. Use it as shown:
    "name": "John Doe",
    "emails": [
            "value": "[email protected]"
    "custom_fields": {
        "ad3c0d01a162c11d660b2710486ff1d79964adb6": "Some Technologies"
    "label_ids": [27]
