I have a postgresql query node after which if query fails to return data, data from a earlier node is not accesible in the “code” node.
let inputData = {}
console.log(“Data”,JSON.stringify(inputData))
console.log("Type : ",typeof($input.item.json.awb))
console.log("Values : ",$(‘Validator’).item.json.barcodes[0])
if(typeof($input.item.json.awb)!==“undefined”){ inputData = $input.item.json
else{
inputData.awb =$(‘Validator’).item.json.barcodes[0]
inputData.sortId = “null”
console.log(“Data2”,JSON.stringify(inputData))
$input[“item”] = inputData
return $input.item;
Code fails at the bold line with error as below
Item Index: 0
Stack
ExpressionError: Can’t get data
at createExpressionError (/usr/local/lib/node_modules/n8n/packages/workflow/dist/WorkflowDataProxy.js:422:20)
at getPairedItem (/usr/local/lib/node_modules/n8n/packages/workflow/dist/WorkflowDataProxy.js:478:27)
at pairedItemMethod (/usr/local/lib/node_modules/n8n/packages/workflow/dist/WorkflowDataProxy.js:672:40)
at Object.get (/usr/local/lib/node_modules/n8n/packages/workflow/dist/WorkflowDataProxy.js:675:40)
at get (<anonymous>)
at VM2 Wrapper.get (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/vm2/lib/bridge.js:447:11)
at /usr/local/lib/node_modules/n8n/packages/nodes-base/dist/nodes/Code:4:39
at /usr/local/lib/node_modules/n8n/packages/nodes-base/dist/nodes/Code:15:2
at VM2 Wrapper.apply (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/vm2/lib/bridge.js:485:11)
at Sandbox.run (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/vm2/lib/nodevm.js:426:23)
at Sandbox.runCodeEachItem (/usr/local/lib/node_modules/n8n/packages/nodes-base/dist/nodes/Code/Sandbox.js:140:42)
at Sandbox.runCode (/usr/local/lib/node_modules/n8n/packages/nodes-base/dist/nodes/Code/Sandbox.js:30:87)
at Object.execute (/usr/local/lib/node_modules/n8n/packages/nodes-base/dist/nodes/Code/Code.node.js:98:38)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/packages/workflow/dist/Workflow.js:659:51)
at /usr/local/lib/node_modules/n8n/packages/core/dist/WorkflowExecute.js:585:68
at processTicksAndRejections (n
