Notion - Get blocks - Unsupported block types
When the Get blocks node is launched with a page that has “unsupported” block types (the new /meet node for example, or the IA resume node), it gives an error.
It would be good if the node should prevent this kind of error by filtering the “unsupported blocks”.
  • n8n version: 1.94.0
  • Database (default: SQLite): PostgreSQL
  • Operating system: Ubuntu
reccmond just enabling on continue on error
Yes, but the blocks that are supported won’t appear in the output
