I add integration on a Notion page, to have API access for the page and all its children, including databases. But in fact, n8n often “doesn’t see” databases. Often, but not always. Until I manually remove the inherited integration and re-add it on the database level.
Important remark. The Integration is set on the page one level above. So the page is the son, and the databases are the grand-sons of the page with the integration. The problem is that if I add the integration on the middle page, it will not frant API access to the databases, its children. This is another issue with Notion access in n8n.
Process
I have a page with an integration added and two tables on the page
They are absent in the n8n list of databases:
I have to open the database as a page, remove the inherited integration and add it manually (see the “Restricted” note)
This fixes the issue for the Table 1 (but not for the Table 2 of course)
Notes
This bug happens very unpredictably. Yesterday with another integration both tables were avalable. Today - only one. When I changed the integration for another one, both became unavailable until manually processed.
