When creating pages in Notion, the notion node provides a form to define blocks to create. For most block types this isn’t too much of an issue but a pain point when it comes to rich text and bullet lists.
Would it make sense to allow an option for the user to just switch to raw json for child blocks?
- these blocks can be generated prior to use in the notion node.
- allows for conversion options from other formats such as markdown
