Notion problem with Select and multi-select properties
When trying to edit properties that are select or multi-select, it does not load the options.
“Error fetching options from Notion”
Issues:
  • There was a problem loading the parameter options from server: “Cannot read properties of undefined (reading ‘split’)”
There is no problem with credentials, because I have many notions automation running right now with this account.
Screenshot_4
  • n8n version: 1.66.0
  • Database Postgress/Redis:
  • Running n8n via Docker
  • Operating system: Linux Ubuntu 22.04
Hi @mcdonnel
Unfortunatel this seems to be one of those annoying frontend bugs… It should work when you exit the node and save and then try to pull the list again.
This happens sometimes when you’re changing a selection in one of the other drop-down fields.
Please let us know if the error persists!
Solved this executing the nodes before. But sometimes it happens, and I have to open in another browser.
