Notion Update DB: There was a problem loading the parameter
i am getting
Issues:
There was a problem loading the parameter options from server: "[object Object]"
Issues:
  • n8n version: 2.9.4
  • Database (default: SQLite): Supabase Postgress
  • n8n EXECUTIONS_PROCESS setting (default: own, main): not changed
  • Operating system: Linux
hi @Keshav-writes-code
The banner at the top of the node is telling you exactly what’s wrong:
you dont have access to that database in Notion. Go to the database in Notion then to Connections, and add your n8n integration there.
let me know :crossed_fingers:
already did
erro 404 from Notion means database id extracted from the url is invalid or inaccessible
Instead of using “By URL”, try to switch to: Database Page → By ID Then paste only the database ID.
lets see if this works
how to get db id
from your node, it’s
8a624d3106af49bf959d9bc087a45669
still getting the same error
ohh, so i was putting the Database url instead of the Database Page Url in that field, that solved it for me
