1st Problem (Main)
The problem I am trying to solve is to update my notion database with info pulled from my github projects (milestones, status & labels) via the graphql.
I made the graphql query to work, I managed to write a python code that rearranges my graphql into the following structure:
I pull data from my notion database, and merge the transformed graphql with the notion db based on Issue Number key.
Everytime this runs it overwrites the same notion row #1 and does not populate all the other nodes…
- n8n version: latest
- Database (default: Notion & Github throught Graphql):
- n8n EXECUTIONS_PROCESS setting (default: own):
- Running n8n via ( n8n cloud):
- Operating system: Windows 10
