I’m using the GraphQL node with OAuth2 API credentials but when the token is expired I have to create a new set of credentials in order to have the node working again. Is there any way OAuth token get’s automagically refreshed if it’s expired?
“extensions”: {
“code”: “UNAUTHENTICATED”
“message”: “Invalid OAuth token”
Workflow only consists of GraphQL node and a manual trigger. Credentials are added to N8N credentials store.
NodeApiError: Invalid OAuth token
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/GraphQL/GraphQL.node.js:463:27)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:670:19)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:652:53
I’m usaing N8N Cloud v1.15.2
After creating a new credential in the credential store in N8N this action works, after an hour when the token is expired it stops working and only creating a new credential fixes the issue, this isn’t acceptable for me, does anyone have a solution for this?
