Hi @xewonder, this change behavior is expected after upgrading to n8n v1 I am afraid. This is explained in a bit more detail here:
The continue setting only applies to the node logic itself, but the expression is resolved outside of the node-specific logic. Perhaps you want to consider a different expression here not relying on the exact amount of items of your Get next positions node? For example:
{{ $('Get next positions').all().map(e => e.json.position2).join('') }}
This should work regardless of the number of items on your Get next positions node. I’ve tested this using this example workflow:
