Hello
I tried 2 solutions, but with the AI agent, it nevers answer in JSON format.
Is there a hack ?
Hello
Is there a hack ?
Hi @Guillaume_C
Are you seeing any errors?
Did you check the option in the node’s parameters?
Trying to help, but need a little more context ![]()
Thank you Ria.
It s an issue of behavior. When you use the AI agent or the openai block, it doesn’t answer the same thing.
Did you already see something like that ?
