OpenAI Node Temperature Setting
Is there a way to set the temperature (which controls the randomness of responses) to over 1.0 in the Open AI chat GPT node?
Open AI allows up to a 2.0 setting for the temperature setting, but the node does not allow you to set it over 1.0.
  • **n8n version 1.76.2 **
  • n8n EXECUTIONS_PROCESS setting: main
  • **Running n8n via cloud **
  • Operating system: Windows 11 Home
Hey @Jeffatsimple , try using an expression.
Does it work?
That did the trick, thanks!!
