Oracle Database module, how to run Stored Procedure\ function using Oracle Module
 We are using the 'Oracle Execute SQL' module to try run a stored procedure, however it fails, when trying to execute it using n8n.
When we run normal SQL commands like 'select * from Uk.employees" it returns a result but when we try run a SP like
Begin
uk.changeEmplyee_name;
End;
We get a ORA-06550 error in the output, when if we run same thing ins SQL Developer it runs fine.
I was wondering if anyone has had same issue, is it limitation or is there specific syntax that is required?
ORA-06650
  • n8n version: 1.121.3
  • Database (default: SQLite): Oracle 19c Standard
  • Operating system: Window
look like typo on our side,
As per notes
Oracle Database node documentation | n8n Docs
BEGIN demo; END;
