Outlook connecting for clients
I run an AI-Agency, i want to connect a clients outlook mailbox to the automation. How can i connect the credentials the best for the client, from a distance on my n8n cloud account with the starter plan? Is there an easy way with minimal setup?
The easiest and safest way to connect a client’s Outlook mailbox in n8n Cloud is to simply let the client authorize it directly. You don’t need their password or any complicated setup just open the credential in n8n, send them the link, and they can log in and approve access on their side. Once they do that, the connection works normally on your workflows and you can manage everything from your account
