Outlook connection issue on self-hosted insance
I am trying to create the connection to my Azure App in order to use Outlook.
All the steps where followed as per documentation: Microsoft credentials | n8n Docs
OAuth Authorization Error
There was a problem generating the authorization URL
Request failed with status code 403
Please help me identify what might be missing from my configuration.
Thank you,
Alex
  • n8n version: 0.208.1
  • Database (default: SQLite): Supabase
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Self-hosted, Docker
hello @alexnemes
You have a very old version of n8n. So the OAuth flow might not work properly there.
Hi @barn4k thank you for the answer.
What n8n version would you recommend so we get the Outlook connection working with no issue?
Thank you,
Alex
Usually, the latest version is good
