Output data at Merge node is not as expected
Hi guys, I am having an issue with the outcome data at the Merge node.
I set up the config for the Merge node as in the picture, and the outcome data should be from the Input 2 after comparing with the Input 1. But if the Input 2 returns empty or does not run, the Merge node gives out results from the Input 1 data which is just the comparing list.
Is it normal behavior of the node, or I set it up wrong? (Fuzzy Compare is on)
Thanks.
Hi @semighoti, I was able to confirm this and seeing you are choosing “Input 2” I agree it seems wrong. I’ll add this to our bug tracker for a closer look and we’ll get back to you as soon as we can.
New version n8n@1.27.2 got released which includes the GitHub PR 8438.
Noted, thanks
