Does anyone know why I can’t install nodes pack?
Every time I try to install I get this error
I installed n8n through cloudron
Just to clarify, you cannot install any of the community nodes?
Then you need to check those logs it is referring to. ![]()
Seems to be something with your setup that is blocking the install of NPM packages.
I have no idea. You will have to wait for one of the smart people to help you out here. ![]()
Ok, thanks
