Paging Discord Channel messages
Issue:
Hey yall, I’ve been trying to figure this out today a few different ways but cant seem to get it to work. I need to pull down all the messages in a certain discord channel and the API has a 100 item page-limit. I tried both a custom workflow using the HTTP module and some pagination looping to no avail (it’s close, just not perfect, linked below) as well as using the prebuilt discord node but when I select “Get Many” it throws a rate-limit error.
Would love some feedback on this on how I can paginate through all the pages of returned messages, thanks!
ERROR: You are being rate limited.
  • n8n version: 1.20.0
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
  • Running n8n via (Docker, npm, n8n cloud, desktop app): DigitalOcean Docker 20.10.21
  • Operating system: Ubuntu 22.04
Hi @datalytyks, this sounds like you just have to add additional wait times between each request. Discord will communicate the rate limits through special headers (discord-api-docs/docs/topics/Rate_Limits.md at main · discord/discord-api-docs · GitHub) so you’d have to evaluate these in your workflow.
I think something like below should do the job:
(I’ve created this example using [email protected], so you might need to update your n8n instance before being able to import this workflow).
Hope this helps!
