Parsing JSON array to extract single element
I have a JSON object that contains an array that’s being returned from an API, and I want to extract only the domain element… what’s the best way to go about it.
    "status_code": 200,
    "error": null,
    "response": {
        "scandata_raw": [
          "datasource": "scan",
          "domain": "domain1.com",
          "scan_date": "2024-09-10 08:23:48"
          "domain": "domain2.net",
          "scan_date": "2024-09-10 08:23:19"
          "domain": "domain3.org",
          "scan_date": "2024-09-10 08:21:06"
I’ve been trying to use a code node to parse out my data, but I don’t know how to access all indices of the array…
Using
return {
  json: {
    domains: $input.all().map(item => item.json.response.scandata_raw)
The data gets passed through virtually unchanged.
If I use
return {
  json: {
    domains: $input.all().map(item => item.json.response.scandata_raw[0])
I only get the domain at index 0
If I use
return {
  json: {
    domains: $input.all().map(item => item.json.response.scandata_raw.domain)
I get no output.
  • n8n version: 1.56.2
  • Database (default: SQLite): Default
  • n8n EXECUTIONS_PROCESS setting (default: own, main): ?
  • Operating system: macOS
Welcome to the community @dmoore44 !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I summarized different approaches in the following workflow
If you are after a single expression that produces domains as an array, you can use
return {
  domains: $input.first().json.response.scandata_raw
    .map(i => {return {domain: i.domain}})
    .map(i => i.domain)
