Hi,
I have a web-hook which receives data from external source, in that web-hook i would like to pick up a specific key/value pairs out… Please refere the example below.
"headers": {
"x-real-ip": “XX”.XX.XX.XX,
"x-forwarded-for": “XX.XX.XX.XX,
"host": "proud-dodo-12.hooks.n8n.cloud",
"x-forwarded-proto": "https",
"x-nginx-proxy": "true",
"connection": "close",
"content-length": "4184",
"content-type": "application/json",
"user-agent": "PostmanRuntime/7.29.0",
"accept": "*/*",
"postman-token": "74c74411-f9ab-4597-b479-ad826aeff379",
"accept-encoding": "gzip, deflate, br"
"params": {
"query": {
"body": [
"body": {
"token": "7fgtWdVkVZdglnioJwnnoGD5",
"team_id": "T032648LE",
"api_app_id": "A02BXC7MW3U",
"event": {
"bot_id": "B02C3J9NCSG",
"type": "message",
"text": " XXXXX”,
"user": "U02BUBQ4C2H",
"ts": "1655387376.165869",
"app_id": "A02BXC7MW3U",
"team": "T032648LE",
"bot_profile": {
"id": "B02C3J9NCSG",
"deleted": false,
"name": "NOC_Ticket_Automator",
"updated": 1629525536,
"icons": {
"image_36": "https://a.slack-edge.com/80588/img/plugins/app/bot_36.png",
"image_48": "https://a.slack-edge.com/80588/img/plugins/app/bot_48.png",
"image_72": "https://a.slack-edge.com/80588/img/plugins/app/service_72.png"
"attachments": [
"id": 1,
"color": "ff0000",
"fallback": “test data`"
"blocks": [
"type": "rich_text",
"block_id": "=UZIm",
"elements": [
"type": "rich_text_section",
"elements": [...] // 7 items
"channel": "C010B2SSYP3",
"event_ts": "1655387376.165869",
"channel_type": "group"
"type": "event_callback",
"event_id": "Ev03LND3Q1U0",
"event_time": 1655387376,
"authorizations": [
"enterprise_id": null,
"user_id": "U02BUBQ4C2H",
"is_bot": true,
"is_enterprise_install": false
"is_ext_shared_channel": false,
"event_context": "4-eyJldCI6Im1lc3NhZ2UiLCJ0aWQiOiJUMDMyNjQ4TEUiLCJhaWQiOiJBMDJCWEM3TVczVSIsImNpZCI6IkMwMTBCMlNTWVAzIn0"
In the above example, i am interested in getting the value for “user” key(“user”: “U02BUBQ4C2H”). I know that we can use a SET node to achieve it, however the payload is not the same all the time, meaning, sometimes the “user” Key will be inside the “body”,“event” block and some time it will be inside the “message” block and sometimes the key will be in “attachment” block kind of nested and we are not sure as to where these key/value will be placed.
What i am trying to achieve is, irrespective of where that key/value present in the payload, i would like to write a javascript function, node which can iterate through the entire payload and find my key/value alone.
The “user” key is unique on the payload, so there are no duplicates. Please refer me to some samples with similar requirement where i can write the code.
