I’ve set up n8n with one main server and two workers. I’m using https://upstash.com/ as the Redis server. Everything runs fine, the workflows are being distributed and executed correctly.
However, every 6 hours Redis seems to be timing out for a short amount of time. Both the main server and the workers at the same time show a “Redis unavailable - trying to reconnect…” message in the logs.
Upstash shows a full uptime status (https://status.upstash.com/) and I couldn’t find anything in the logs that looks suspicious. So I guess it’s something up with n8n.
If the timeouts are short enough for n8n to recover, and if you have not changed the default timeout, then your timeouts are shorter than 10 seconds, which might be why they are not being reported as downtime by Upstash. Can you deploy Redis elsewhere to rule it out?
After trying out different Redis server, I was able to resolve this issue.
My first server was from upstash.com, which had those connectivity issues. I then tried self-hosting Redis. This resulted in even more connectivity issues. Lastly, I tried redis.com. This worked flawlessly.
I don’t know what I did wrong and I’d be happy if someone knows why the self-hosted Redis instance didn’t work.
