Personal project not found after major upgrade n8n - Selfhost
I am doing a major upgrade of my N8N selfhost from 1.119.2 to 2.2.3.
I faced the issue regarding postgres as it’s missing pgcrypto module and I already had it enabled. I could access the n8n UI and login, but I always received Personal project not found. I checked in the database, my user has personal project.
I do inspect the browser network tab, and this endpoint rest/projects/my-projects responds my personal project, but this endpoint rest/projects/personal respond 404.
Please anyone has any idea how can I fix this, I’m stuck the whole day.
installHook.js:1 ResponseError: Could not find a personal project for this user
Hello,
I had the same problem. Somehow the user database got corrupted. I had no other option than to manually adjust the creatorId to the correct user in the project table in the database.
I also cleaned up the project_relation table.
Best regards
Thank you. I am able to fix it now.
I’m not quite sure what’s the actual problem because I was creating a new pod and trying to do data migration, but it still causes the issue. Reverting to my existing database and enable the pgcrypto, I could see the new migration is running and the new version is able to deploy.
Just to be cautious if anyone plan to do migration to a new database as there’s any issue with existing db or something, probably the same issue as mine might be happening.
I will close this topic now.
