the connection with Pinecone may have some problems when trying to connect with the indexes store. not bringing up the list of indexes properly
- n8n version:
- Database (default: SQLite):
- Operating system:
n8n version [online]: 1.31.2
template: Chat with PDF docs using AI (quoting sources) by David Roberts [Chat with PDF docs using AI (quoting sources) | n8n workflow template]
Steps Taken:
1 - Create Pinecone index - OK
2 - Connect n8n with Pinecone by providing API Key - OK [got Connection tested successfully]
3 - In step/node “Add to Pinecone Vector Store”, the field Pinecone Index doesn’t retrieve my indexes in the drop-down list. By trying copying/pasting the Pinecone Index ID (and choosing By ID) I’m getting the error : ERROR: Index test-index not found
Please check that the index exists in your vector store
LOG:
NodeOperationError: Index test-index not found
at Object.populateVectorStore (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/vector_store/VectorStorePinecone/VectorStorePinecone.node.js:107:19)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/vector_store/shared/createVectorStoreNode.js:174:21)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:730:19)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:660:53
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1062:20
I’ve double-checked index ID several times. Deleted, Created again. Nothing makes the Index be found on the N8N Pinecone node.
hello team, is it possible to investigate given the details shared? I believe it may have an error on the platform (pinecone node)
I see the same error.
Tried the “starter” solution mentioned in another thread - it doesn’t work now.
Has anyone find a workaround ?
