To test the workflow from a specific trigger, instead of clicking the Test button at the bottom of the page, first click the little play button on top of the trigger node you want to start from, then click the play button on the node you want to run up to, for example: play on Address Changed then play on EMpty Billing ID. This will ensure your workflow starts from the correct node and then continues to the node up until
