anytime i ask Plan and Execute Agent node a question, i get this error. the workflow is simple and basic.
- Error:
Problem in node ‘AI Agent‘
Cannot read properties of undefined (reading ‘text’)
or
-Error
Unable to parse JSON response from chat agent. Question: Can you provide a step-by-step guide on how to create a new Next.js project using the npx create-next-app command? Thought: To create a new Next.js project, we can use the npx create-next-app command. This command will guide us through the process of setting up a new Next.js project. Action: $JSON_BLOB { "action": "terminal", "action_input": "npx create-next-app my-next-app" } Troubleshooting URL: OUTPUT_PARSING_FAILURE | 🦜️🔗 Langchain
- **n8n version: 1.73.1
- **Database (default: SQLite):Supabase
- **n8n EXECUTIONS_PROCESS setting (default: own, main): default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
- **Operating system:Windows
