Please help me resolve the errors encountered when creating a RAG
Receive uploaded files via webhook.
Save the received files to a local path.
NodeOperationError: The item has no binary field ‘data’ [item 0] at assertBinaryData (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/node-execution-context/utils/binary-helper-functions.ts:74:9) at Object.assertBinaryData (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/node-execution-context/execute-context.ts:104:21) at ExecuteContext.extractDataFromPDF (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/utils/binary.ts:158:34) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Files/ExtractFromFile/actions/pdf.operation.ts:92:42) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Files/ExtractFromFile/ExtractFromFile.node.ts:130:35) at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1253:31) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1427:22) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1727:38 at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_5aee33ef851c7de341eb325c6a25e0ff/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2303:11
hello @Deno1
change the input binary field from data to file in the second node
