Please help with the query issue
I’m new to n8n. I built a workflow with postgres db at the backend. I have a query in one node which pulls the schema tables and passing it to the next node. The output for some reason has more tables than the actual schema tables. I use gpt4. I tried changing the prompt and instructed not to come up with new tables but no luck. Please help! Thanks you.
Hey @cool9898981 hope all is well. Welcome to the community.
Could you try to add some visuals to your post, like screenshots of the actual schema and what the request comes back with… Also share your workflow, so we can take a look at what you were doing that led to the problem.
