Plex Playlister Flow
Hi there, I have recently published a workflow that allows you to automatically classify audio tracks and create Playlists using local instances of Plex and Ollama.
Since I’m not allowed to post direct links to the n8n template (don’t know why) I will just show how to get the template :
Go to the workflow section on the main page and enter the below entry in the search box :
