Populate advanced tables in Notion
The problem is simple: I have tables in Notion with relational dependency. in Notion language: Linked databases: Using linked databases
In order to populate with POST API call, i need DB ID. you can imagine that if i want proper automation, spamming Notion to get the DB ID to route correctly is API heavy, time consuming and inneficient. Simple solution is to do it once in a sub flow and populate variable. unfortunately, global variables in N8N are only under PRO plan, costs of which i cant justify for what i need.
you will get error 400, flow error that will complain about parent ID.
(Select the nodes on your canvas and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to co{
  "nodes": [
      "parameters": {
        "jsCode": "// Take normalized payload and fan out one item per position\nconst r = $input.first().json.received;\n\n// <-- put YOUR database id here -->\nconst DB_ID = 'X_Y_Z_ID';\n\nconst items = (r.positions || []).map(p => ({\n  json: {\n    dbId: DB_ID,\n    asOf: r.asOf,\n    platform: r.platform,\n    account: r.accountLabel || '',\n    currency: r.currency || '',\n    symbol: (p.symbol || p.rawSymbol || '').toUpperCase(),\n    name: p.name || '',\n    qty: p.qty ?? null,\n    avgCost: p.avgCost ?? null,\n    lastPrice: p.lastPrice ?? null,\n    value: p.value ?? null,\n    pnl: p.pnl ?? null,\n    // Notion \"percent\" wants decimals (0.25 for 25%)\n    pnlPctDecimal: (p.pnlPct == null ? null : Number(p.pnlPct) / 100)\n  }\n}));\n\nreturn items;\n"
      "type": "n8n-nodes-base.code",
      "typeVersion": 2,
      "position": [
        400,
        -144
      "id": "censorship applied",
      "name": "Prep Items"
      "parameters": {
        "method": "POST",
        "url": "https://api.notion.com/v1/pages",
        "authentication": "predefinedCredentialType",
        "nodeCredentialType": "notionApi",
        "sendBody": true,
        "contentType": "raw",
        "rawContentType": "JSON (application/json)",
        "body": "={{ \n  JSON.stringify({\n    parent: { type: \"database_id\", database_id: $json.dbId },\n    properties: {\n      \"Ticker\": { title: [{ text: { content: $json.symbol } }] },\n      \"OS/ As Of\": { date: { start: $json.asOf } },\n      \"OS/ Platform\": { rich_text: [{ text: { content: $json.platform || \"\" } }] },\n      \"OS/ Account\": { rich_text: [{ text: { content: $json.account || \"\" } }] },\n      \"OS/ Currency\": { rich_text: [{ text: { content: $json.currency || \"\" } }] },\n      \"OS/ Qty\": { number: $json.qty ?? null },\n      \"OS/ Avg Cost\": { number: $json.avgCost ?? null },\n      \"OS/ Last Price\": { number: $json.lastPrice ?? null },\n      \"OS/ Value\": { number: $json.value ?? null },\n      \"OS/ P/L\": { number: $json.pnl ?? null },\n      \"OS/ P/L%\": { number: $json.pnlPctDecimal ?? null }\n    }\n  })\n}}\n",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        624,
        -144
      "id": "bd227741-590f-48bb-aec2-eee883524962",
      "name": "HTTP (Page Creation)",
      "credentials": {
        "notionApi": {
          "id": "SH22k3ZejUisCD7e",
          "name": "Notion account 2"
  "connections": {
    "Prep Items": {
      "main": [
            "node": "HTTP (Page Creation)",
            "type": "main",
            "index": 0
  "pinData": {},
  "meta": {
    "instanceId": "885effde3483a0b2ee84c6ff345c166eaa425e59d0566252a358b27363e816ba"
}py and paste the workflow.)
  • n8n version: latest stable 1.6xxx
  • Running n8n via (Docker, npm, n8n cloud, desktop app):n8n cloud
  • Operating system: win11
