Hello,
Has anyone populated a Miro.com mindmap from an Excel spreadsheet from n8n.io?
I have posted the same question on Miro but received no response
Many thanks
Hello,
Many thanks
Hi @vane.digital, it looks like Miro does offer a REST API: REST API introduction
So you should be able to use the available endpoints using n8n’s HTTP Request node, though this isn’t something I have tried first hand. Perhaps you want to give it a go and let us know if you’re running into any problems on the n8n side of things?
Thank you @MutedJam - that’s a start. Will give it a try.
