๐Ÿž Possible bug in IF node: expression evaluates correctly but routing goes to True branch
Hi,
I believe Iโ€™ve run into a bug (or at least very unintuitive behavior) in the IF node when using expressions, and Iโ€™d like to check whether this is expected or not.
Context / goal
Iโ€™m using Split in Batches and want to wait only between batches, i.e.:
  • batch #1 โ†’ no wait
  • batch #2+ โ†’ wait (rate-limit OCR API)
The condition is based on:
$("Split in Batches").context["currentRunIndex"]
which is 0 for the first batch, 1, 2, โ€ฆ for subsequent batches.
What I tried
1. String comparison in IF node
IF node configuration:
  • Condition type: String
  • Value 1 (Expression):
{{ String($("Split in Batches").context["currentRunIndex"] ?? "0").trim() }}
  • Operation: is not equal
  • Value 2: "0" (string, not number)
  • Convert types where required: OFF
2. Debug confirms expression is correct
Using a Set node right before the IF, I verified:
  • currentRunIndex = 0
  • typeof currentRunIndex = number
  • String(...).trim() = "0"
  • String(...).trim() !== "0" = false
  • Expression preview in IF node shows Result: false
So logically, the IF should go to the False branch on the first batch.
:cross_mark: What actually happens
Despite all of the above:
  • The IF node routes items to the True branch
  • The downstream Wait node executes on the first batch
  • This happens consistently
I also tried:
  • Boolean conditions (is true / is false)
  • Explicit boolean expressions
  • Number comparisons
  • Turning Convert types where required ON and OFF
In multiple cases:
  • The expression preview shows the correct result
  • But runtime routing still goes to the True branch
This behavior looks very similar to the issue described here:
http://community.n8n.io/t/if-node-expression-returns-false-but-still-goes-to-true-branch/129452/2
Please share your workflow. or the part of it that doesnโ€™t work. That makes it a lot easier to see what is going on.
