My n8n installation is working fine with all the webhooks in http.
In order to make some improvements i am trying to use HTTPS.
For now, my webhooks URL looks like http://{{domain_name}}/webhook/…
I would like to change it to https://{{domain_name}}/webhook/…
I am using docker to launch n8n and an set up the following parameter :
-e N8N_HOST=“domain_name” -e VUE_APP_URL_BASE_API=“https://domain_name/” -e WEBHOOK_TUNNEL_URL=“https://domain_name/”
The issue is that my last POST Webhook is still in http. So the request is blocked by Firefox.
The error message is like : The information entered will be transmitted in clear (without encryption). They can therefore possibly be intercepted and read during their routing.
Are you sure you want to send this information?
But even if yes is clicked, no information is send…
Do you have any clue on this one?
To use HTTPS you would need to set WEBHOOK_URL to your full url and make sure that you have your SSL certificate configured on your reverse proxy in the normal way.
Thanks almost ok on my side.
I forget to tell something.
In my worflow I add an http request node. when it is active my https workflow is not working but when it is disable my https workflow is working fine…
I tried to modify the URL in the http request node in http or https but still do not work…strange…
