Postal code range from Brazil
I have a chatwoot webhook node that returns custom attributes:
“custom_attributes”:
“rua”: “vilebaldo aguiar”, (rua = street)
“cidade”: “fortaleza”, (cidade = city)
“numero”: “3220”, (numero = number)
After that, I make an http request from the viacep api to return postal codes.
The problem is that the api returns several postal codes based on ranges of numbers.
How do I create a javascript code that returns the corresponding postalcode if the number is between the right range?
7NR9jhpgBP1AdIfl
Can you share an example of the output?
What’s this?
@bartv I think that’s the ID of his workflow.
@marcelohhirata Please see the video below on how to embed a workflow into the forum for us to see
Please also share a sample of the response from the postal code API as we will need that to write any code
@marcelohhirata do you still need help with this? If so, we’ll need a little more information to better understand the problem.
