Postgres Memory Problem
Greetings,
I’ve been having problem with my Postgres memory whenever I try to upload a file using telegram. For some reason the AI agent keeps sending two outputs to the memory. I already tried changing the memory to a simple one, but the same error keeps happening. So, it must be the AI agent node, from my understanding. How can I fix that?
This is my workflow:
  • **n8n version: 1.99.1
  • **n8n EXECUTIONS_PROCESS setting default: own, main
  • **Running n8n via: Docker
  • **Operating system: Ubuntu 24.04
try to make the ID as a string with add double quotation mark (") to your key.
in ur case, you can try this "{{ $('Receive Message').item.json.message.chat.id }}"
That was the problem. Thanks a lot @cutecatcode!
