Postgres Node Fails in Queue Mode: “Cannot read properties of undefined (reading ‘execute’)”
Hi everyone,
I’m encountering a critical issue when running workflows in queue mode using the Postgres node. As soon as a workflow is activated and runs in production, the following error appears:
Error
Error: Cannot read properties of undefined (reading ‘execute’)
at Queue.onFailed (/usr/local/lib/node_modules/n8n/node_modules/bull/lib/job.js:516:18)
at Queue.emit (node:events:536:35)
at Object.module.exports.emitSafe (/usr/local/lib/node_modules/n8n/node_modules/bull/lib/utils.js:50:20)
at EventEmitter.messageHandler (/usr/local/lib/node_modules/n8n/node_modules/bull/lib/queue.js:476:15)
at EventEmitter.emit (node:events:524:28)
at DataHandler.handleSubscriberReply (/usr/local/lib/node_modules/n8n/node_modules/ioredis/built/DataHandler.js:80:32)
at DataHandler.returnReply (/usr/local/lib/node_modules/n8n/node_modules/ioredis/built/DataHandler.js:47:18)
at JavascriptRedisParser.returnReply (/usr/local/lib/node_modules/n8n/node_modules/ioredis/built/DataHandler.js:21:22)
at JavascriptRedisParser.execute (/usr/local/lib/node_modules/n8n/node_modules/redis-parser/lib/parser.js:544:14)
at Socket. (/usr/local/lib/node_modules/n8n/node_modules/ioredis/built/DataHandler.js:25:20)
It seems like the node tries to execute something that is undefined, causing the entire execution to fail immediately.
This only happens in queue mode in production, in regular and test mode, everything works fine. I suspect this might be a bug related to how the Postgres node is handled within the worker.
Is anyone else experiencing this? Any ideas or suggestions on how to fix?
Thanks.
  • n8n version: 1.91.2
  • Database (default: SQLite): PostgreSQL
  • Running n8n via (Docker, npm, n8n cloud, desktop app): self-hosted queue mode
Hola :slight_smile:
This looks like a bug in how the Postgres node is handled in queue mode. Most likely, the execute method isn’t properly registered in the worker context, which causes it to be undefined.
In regular mode it works fine because everything runs in the main thread. But queue mode uses separate worker processes, and the node might not be fully loaded there.
Quick tip: try updating n8n to the latest version, or run Postgres actions outside queue mode for now as a workaround. Hope it helps!
