Hello
I have a problem getting my query work with in operation it is an array of integers
but only getting the first one
this is my array from previous node
and below is the query parameter , getting only the result of first item in the array using .join(‘,’)
and without it getting same result
Same query give all result directly if called it in db
Thanks
