My n8n is hosted using IIS reverse proxy, but it behaves a bit weird. e.g i used a Postgres Node, and provided credentials. all modes except Select can access the schema and tables, but when i used Select, it gives error message ‘Could not load List, Please check your credentials’
When i tried to access directly in the server using localhost:5678, there’s no problem to use the Select mode on postgres node. so my sense it must be something wrong in IIS proxy server
I have followed the installation process in the tutorial. is there anyone who have faced the same issue? is there any solution for this? or would spawning a new ec2 instance in aws will be a quicker and easier fix?
- n8n version: 1.7.1
- Database (default: SQLite): Postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: Windows
