Postman issues
I keep giving the Same request and it works in Postman, but fails inside n8n with auth errors.
It’s probably cause n8n is probably not sending headers exactly the way you think.
you can fix it by
  • Checking if headers are actually being passed (not just set in UI)
  • Avoiding hidden whitespace in API keys
  • Using “RAW headers” instead of relying on credential helpers when debugging
Most of the time, it’s a silent formatting issue and not the API itself.
