Privacy-First Form Builder for n8n
I’m excited to share something built for n8n that I think will make life easier for anyone collecting data via forms—especially if you care about privacy.
When it comes to building forms for n8n, you really have two main options:
:one: Build your own form with HTML or any frontend framework
While this gives you full control, it’s surprisingly challenging—especially if you need to build custom forms for every project:
:cross_mark: Requires coding skills and ongoing maintenance
:cross_mark: You need to write and maintain code for every new form, which gets tedious and time-consuming
:cross_mark: Handling validation, error states, and security is all on you
:two: Use existing form builders in the market
These are easier to set up, but come with their own limitations:
:cross_mark: Most store your form data on their servers, raising privacy and compliance concerns
:cross_mark: Direct integration with n8n usually requires extra steps, workarounds, or even paid plans
:cross_mark: You get limited control over data routing and customization
:cross_mark: Embedding and branding options can be restrictive, and adapting to your workflow isn’t always straightforward
That’s exactly why I built Form0—a form builder designed specifically for privacy and automation platforms like n8n:
:white_check_mark: Truly privacy-first: Form submissions are never stored on our servers—data is sent directly to your webhook.
:white_check_mark: Customizable and flexible: Choose from a wide range of field types, set up validation, and organize your form layout to fit your needs.
:white_check_mark: Seamless n8n integration: Just drop in your webhook URL and you’re ready.
:white_check_mark: Unlimited forms with no submission limits: Create as many forms as you need and collect unlimited responses—every submission is instantly and securely routed to your webhook, so your only limit is what your own backend can handle.
:white_check_mark: Secure webhook management: Your webhook URLs are encrypted and securely stored on our backend.
:white_check_mark: Compliant by design: Our zero-storage architecture and secure data handling ensure you fully meet privacy regulations like GDPR and CCPA.
:white_check_mark: Responsive and easy to embed: Works great on any device, and you can share via link or embed anywhere.
:white_check_mark: No coding required: Build, preview, and launch forms visually—no coding knowledge needed at all.
How does it work? - Building a form with Form0 in 3 simple steps:
  1. Design your form with our drag-and-drop builder—add fields, set up validation, and preview changes instantly.
  2. Connect your backend by plugging in your n8n webhook and testing with sample submissions to ensure everything flows smoothly.
  3. Share your form via link or embed it on your site. Submissions go straight to your backend, never stored with us.
What’s next for Form0?
I’m working on features like more options to customize the look and feel, conditional logic for smarter forms and even AI-powered form building to make setup even faster. If you have ideas or requests, I’d love to hear them!
Curious? Try it at Form0.app and launch your privacy-first form in minutes—completely free.
