Problem creating credential SQLITE_ERROR: near "-": syntax error
Hey everyone,
I’m running into a major issue on my self-hosted n8n setup. Since yesterday, I can’t save anything anymore — not credentials, not workflows, not even small changes. Every time I try, it either does nothing or throws an error like this:
vbnet
KopierenBearbeiten
I’ve not changed anything manually in the setup or config recently. The problem appeared out of nowhere.
Some context:
  • I’m running the latest n8n version (1.95.3) via Docker (docker.n8n.io/n8nio/n8n)
  • Hosted on a Linux VPS with Traefik and Docker Compose
  • Using SQLite as the database (default setup)
  • Everything was working fine until recently
  • In the n8n cloud, the same workflows work and save just fine
  • I don’t really know much about servers or databases, so I’m totally lost here
What could cause this? Do I need to clean or reset the database somehow? Or is this a known bug in this version?
Any help is massively appreciated :folded_hands:
Hey @Johannes_Kofler ,
I would suggest to check if the db is not corrupted first
Run this inside your Docker container:
docker exec -it <your-n8n-container-name> bash sqlite3 /home/node/.n8n/database.sqlite
Then in the SQLite prompt:
PRAGMA integrity_check;
If you get ok, the DB isn’t corrupted.
Exit with .exit
Thank you all working fine again after restarting the server lol
