<your workflow>
I’m afraid the JSON generated for you is not valid workflow to be imported into n8n.
I only managed to restore it partially. It’s too tedious to do so. You have a better chances to build it from scratch. Perhaps you can simply add the missing bits to the below
The “basic” template I can do drag and drop more or less…
I wonder if it is possible to feed Claude or other services enough documentation from n8n (code parameters, …) so that it could write me / us valid .json files in the future.
We are thinking about adding that functionality into n8n itself. Though I also heard that some independent developers are working on such a service (separately from n8n) specifically aimed at building n8n workflows with AI. Unfortunately I am not aware of already existing service like that.
Could you provide sufficient documentation on code structure for the sake of giving it a try myself?
I mean there must be certain set of rules for each nodes, comnections, … - properties and settings that e.g. Claude should be able to take into account…
