Problem in node ‘Code in Python (Beta)‘ RuntimeError: Blocked for security reasons
When using Python in a Code node, will cause an error.
I’ve added - N8N_ALLOWED_NETWORKS=0.0.0.0/0
  • NODE_FUNCTION_ALLOW_EXTERNAL=* to my Docker Compose configuration.
I’ve also shut down and restarted Docker Compose.
But the issue persists.
Node type
n8n-nodes-base.code
Node version
2 (Latest)
n8n version
1.114.4 (Self Hosted)
Stack trace
Error: RuntimeError: Blocked for security reasons at PythonSandbox.getPrettyError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Code/PythonSandbox.ts:101:11) at PythonSandbox.runCodeInPython (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Code/PythonSandbox.ts:85:15) at PythonSandbox.runCodeAllItems (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Code/PythonSandbox.ts:46:27) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Code/Code.node.ts:198:14) at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1091:8) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1272:11) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1673:27 at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2287:11
(Select the nodes on your canvas and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow.){
  "nodes": [
      "parameters": {},
      "type": "n8n-nodes-base.manualTrigger",
      "typeVersion": 1,
      "position": [
        0,
        0
      "id": "21617019-a62f-4f07-8dfb-aae30432e8d5",
      "name": "When clicking ‘Execute workflow’"
      "parameters": {
        "url": "https://news.ycombinator.com/",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        224,
        0
      "id": "484be7b7-d24d-4223-9cfa-2c86ef591349",
      "name": "HTTP Request"
      "parameters": {
        "operation": "extractHtmlContent",
        "extractionValues": {
          "values": [
              "key": "序号",
              "cssSelector": "tr .athing .rank",
              "returnArray": true
              "key": "文章标题",
              "cssSelector": "tr .titleline >a",
              "returnArray": true
              "key": "项目ID待处理",
              "cssSelector": "tr .subtext .age",
              "returnArray": true
              "key": "发布时间UTC待处理",
              "returnValue": "attribute",
              "attribute": "title",
              "returnArray": true
              "key": "打分",
              "cssSelector": "tr .subtext .score",
              "returnArray": true
              "key": "评论数",
              "cssSelector": ".subline > a:nth-last-of-type(1)",
              "returnArray": true
              "key": "文章链接",
              "attribute": "href",
              "returnArray": true
        "options": {}
      "type": "n8n-nodes-base.html",
      "typeVersion": 1.2,
      "position": [
        432,
        0
      "id": "506bf0f5-a58d-4521-8a6c-65d4e095ad57",
      "name": "HTML"
      "parameters": {
        "language": "python",
        "pythonCode": "# 准备一个空列表,用于存放我们处理后的新项目\nprocessed_items = []\n\n# --- 遍历所有输入的项目 ---\n# 这个循环会为你的每一个 item (每一行数据) 都执行一次\nfor item in _input.all():\n    # 从当前 item 的 json 数据中安全地获取 '评论链接'\n    comment_link = item.json.get('评论链接')\n    \n    # 只有当链接存在时,我们才为它创建一个新项目\n    if comment_link:\n        # --- 构建一个新的、只包含 '评论链接' 字段的项目 ---\n        new_item = {\n            'json': {\n                '评论链接': comment_link\n            }\n        }\n        \n        # 将这个新创建的、干净的项目添加到我们的结果列表中\n        processed_items.append(new_item)\n\n# 返回由多个独立项目组成的新列表\nreturn processed_items"
      "type": "n8n-nodes-base.code",
      "typeVersion": 2,
      "position": [
        800,
        192
      "id": "1233e598-db7e-4adb-bf51-d213afde50e2",
      "name": "保留评论链接"
      "parameters": {
        "pythonCode": "from datetime import datetime, timedelta\nimport re\n\n# 你的输入只有一个 item,所以这个循环只会执行一次\nfor item in _input.all():\n    json_data = item.json\n\n    # --- 1. 处理 '项目ID待处理' 列表 ---\n    project_ids_raw_list = json_data.get('项目ID待处理', [])\n    processed_links = []  # 创建一个新列表来存放处理后的结果\n    \n    # 内部循环,遍历列表中的每一个链接字符串\n    for link_str in project_ids_raw_list:\n        try:\n            extracted_id = link_str.split('[')[1].split(']')[0]\n            full_link = f\"https://news.ycombinator.com/{extracted_id}\"\n            processed_links.append(full_link)\n        except (IndexError, AttributeError):\n            processed_links.append('格式错误')\n            \n    # 用处理好的新列表替换旧字段,并重命名\n    json_data['评论链接'] = processed_links\n    if '项目ID待处理' in json_data:\n        del json_data['项目ID待处理']\n\n    # --- 2. 处理 '发布时间UTC待处理' 列表 ---\n    publish_times_raw_list = json_data.get('发布时间UTC待处理', [])\n    processed_times = []\n    \n    for time_str in publish_times_raw_list:\n        try:\n            time_part = time_str.split(' ')[0]\n            utc_time = datetime.strptime(time_part, '%Y-%m-%dT%H:%M:%S')\n            beijing_time = utc_time + timedelta(hours=8)\n            formatted_time = beijing_time.strftime('%Y-%m-%d %H:%M:%S')\n            processed_times.append(formatted_time)\n        except (ValueError, IndexError, AttributeError):\n            processed_times.append('时间格式错误')\n\n    json_data['北京发布时间'] = processed_times\n    if '发布时间UTC待处理' in json_data:\n        del json_data['发布时间UTC待处理']\n        \n    # --- 3. 处理 '打分' 列表 ---\n    scores_raw_list = json_data.get('打分', [])\n    processed_scores = []\n    \n    for score_str in scores_raw_list:\n        try:\n            # 确保 score_str 是字符串,以防列表中有 None 或其他类型\n            score_value = int(str(score_str).replace('points', '').strip())\n            processed_scores.append(score_value)\n        except (ValueError, AttributeError):\n            processed_scores.append(0) # 如果转换失败,给一个默认值 0\n\n    json_data['打分'] = processed_scores\n    \n    # --- 4. 处理 '评论数' 列表 ---\n    comments_raw_list = json_data.get('评论数', [])\n    processed_comments = []\n    \n    for comment_str in comments_raw_list:\n        match = re.search(r'\\d+', str(comment_str))\n        if match:\n            processed_comments.append(int(match.group(0)))\n        else:\n            processed_comments.append(0)\n\n    json_data['评论数'] = processed_comments\n\n# 返回被修改后的项目 (仍然只有一个 item)\nreturn _input.all()"
      "typeVersion": 2,
      "position": [
        640,
        0
      "id": "90479bc4-485d-4afb-8e1b-69954d2daa38",
      "name": "网页内容"
      "parameters": {
        "pythonCode": "import requests\n# 导入所需的库\nimport requests\nfrom bs4 import BeautifulSoup\n\n# --- 定义一个可复用的爬虫函数 ---\ndef scrape_web_content(url):\n    \"\"\"\n    接收一个 URL,爬取其网页内容,并返回HTML文本。\n    包含基本的错误处理和超时设置。\n    \"\"\"\n    # 检查URL是否有效\n    if not url or not isinstance(url, str) or not url.startswith('http'):\n        return \"无效或空的 URL\"\n\n    headers = {\n        'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.124 Safari/537.36'\n    }\n\n    try:\n        # 发送 HTTP GET 请求\n        response = requests.get(url, headers=headers, timeout=10)\n        response.raise_for_status() # 如果请求失败 (如 404, 503), 则抛出异常\n        \n        # 直接返回响应的文本内容 (HTML)\n        return response.text\n\n    except requests.exceptions.RequestException as e:\n        return f\"爬取失败: {e}\"\n    except Exception as e:\n        return f\"处理时发生未知错误: {e}\"\n\n# --- 主逻辑:遍历 n8n 的输入项目 ---\n# 这个循环会为你的每一个 item (每一行数据) 都执行一次\nfor item in _input.all():\n    json_data = item.json\n\n    # 1. 从当前 item 中获取 '评论链接'\n    comment_url = json_data.get('评论链接')\n    \n    # 2. 调用爬虫函数抓取内容\n    comment_content = scrape_web_content(comment_url)\n    \n    # 3. 将爬取到的内容添加到当前 item 的 json 数据中,创建新字段 '评论内容'\n    item.json['评论内容'] = comment_content\n\n# 返回被修改后的所有项目\nreturn _input.all()"
      "typeVersion": 2,
      "position": [
        1008,
        192
      "id": "868d0b9a-7184-4085-8e02-961a4f2efd5d",
      "name": "Code in Python (Beta)"
  "connections": {
    "When clicking ‘Execute workflow’": {
      "main": [
            "node": "HTTP Request",
            "type": "main",
            "index": 0
    "HTTP Request": {
      "main": [
            "node": "HTML",
            "type": "main",
            "index": 0
    "HTML": {
      "main": [
            "node": "网页内容",
            "type": "main",
            "index": 0
    "保留评论链接": {
      "main": [
            "node": "Code in Python (Beta)",
            "type": "main",
            "index": 0
    "网页内容": {
      "main": [
            "node": "保留评论链接",
            "type": "main",
            "index": 0
  "pinData": {
    "网页内容": [
        "序号": [
          "1.",
          "2.",
          "3.",
          "4.",
          "5.",
          "6.",
          "7.",
          "8.",
          "9.",
          "10.",
          "11.",
          "12.",
          "13.",
          "14.",
          "15.",
          "16.",
          "17.",
          "18.",
          "19.",
          "20.",
          "21.",
          "22.",
          "23.",
          "24.",
          "25.",
          "26.",
          "27.",
          "28.",
          "29.",
          "30."
        "文章标题": [
          "Meta Superintelligence's surprising first paper",
          "Pipelining in psql (PostgreSQL 18)",
          "The Flummoxagon",
          "Show HN: Rift – A tiling window manager for macOS",
          "Show HN: Sober not Sorry – free iOS tracker to help you quit bad habits",
          "I/O Multiplexing (select vs. poll vs. epoll/kqueue)",
          "4x faster LLM inference (Flash Attention guy's company)",
          "Coral Protocol: Open infrastructure connecting the internet of agents",
          "Ask HN: Abandoned/dead projects you think died before their time and why?",
          "Anthropic's Prompt Engineering Tutorial",
          "Vancouver Stock Exchange: Scam capital of the world (1989) [pdf]",
          "The World's 2.75B Buildings",
          "Show HN: A Lisp Interpreter for Shell Scripting",
          "Paper2Video: Automatic Video Generation from Scientific Papers",
          "A Guide for WireGuard VPN Setup with Pi-Hole Adblock and Unbound DNS",
          "Microsoft only lets you opt out of AI photo scanning 3x a year",
          "CamoLeak: Critical GitHub Copilot Vulnerability Leaks Private Source Code",
          "Testing two 18 TB white label SATA hard drives from datablocks.dev",
          "LineageOS 23",
          "Windows Subsystem for FreeBSD",
          "Show HN: I made an esoteric programming language that's read like a spellbook",
          "Superpowers: How I'm using coding agents in October 2025",
          "Google blocks Android hack that let Pixel users enable VoLTE anywhere",
          "The <output> Tag",
          "The World Trade Center under construction through photos, 1966-1979",
          "How Apple designs a virtual knob (2012)",
          "Floating Electrons on a Sea of Helium",
          "Vibing a non-trivial Ghostty feature",
          "Beyond indexes: How open table formats optimize query performance",
          "Spyware maker NSO Group confirms acquisition by US investors"
        "打分": [
          301,
          90,
          39,
          144,
          29,
          56,
          7,
          26,
          135,
          167,
          94,
          61,
          59,
          53,
          88,
          629,
          44,
          181,
          240,
          261,
          16,
          361,
          164,
          768,
          217,
          143,
          8,
          270,
          64,
          108
        "评论数": [
          160,
          13,
          5,
          65,
          23,
          12,
          0,
          4,
          414,
          18,
          41,
          23,
          8,
          12,
          10,
          217,
          9,
          108,
          93,
          107,
          1,
          191,
          58,
          171,
          105,
          91,
          0,
          125,
          3,
          72
        "文章链接": [
          "https://paddedinputs.substack.com/p/meta-superintelligences-surprising",
          "https://postgresql.verite.pro/blog/2025/10/01/psql-pipeline.html",
          "https://n-e-r-v-o-u-s.com/blog/?p=9827",
          "https://github.com/acsandmann/rift",
          "https://sobernotsorry.app/",
          "https://nima101.github.io/io_multiplexing",
          "https://www.together.ai/blog/adaptive-learning-speculator-system-atlas",
          "https://arxiv.org/abs/2505.00749",
          "item?id=45553132",
          "https://github.com/anthropics/prompt-eng-interactive-tutorial",
          "https://scamcouver.wordpress.com/wp-content/uploads/2012/04/scam-capital.pdf",
          "https://tech.marksblogg.com/building-footprints-gba.html",
          "https://github.com/gue-ni/redstart",
          "https://arxiv.org/abs/2510.05096",
          "https://psyonik.tech/posts/a-guide-for-wireguard-vpn-setup-with-pi-hole-adblock-and-unbound-dns/",
          "https://hardware.slashdot.org/story/25/10/11/0238213/microsofts-onedrive-begins-testing-face-recognizing-ai-for-photos-for-some-preview-users",
          "https://www.legitsecurity.com/blog/camoleak-critical-github-copilot-vulnerability-leaks-private-source-code",
          "https://ounapuu.ee/posts/2025/10/06/datablocks-white-label-drives/",
          "https://lineageos.org/Changelog-30/",
          "https://github.com/BalajeS/WSL-For-FreeBSD",
          "https://github.com/sirbread/spellscript",
          "https://blog.fsck.com/2025/10/09/superpowers/",
          "https://www.androidauthority.com/pixel-ims-broken-october-update-3606444/",
          "https://denodell.com/blog/html-best-kept-secret-output-tag",
          "https://rarehistoricalphotos.com/twin-towers-construction-photographs/",
          "https://jherrm.github.io/knobs/",
          "https://arstechnica.com/science/2025/10/new-qubit-tech-traps-single-electrons-on-liquid-helium/",
          "https://mitchellh.com/writing/non-trivial-vibing",
          "https://jack-vanlightly.com/blog/2025/10/8/beyond-indexes-how-open-table-formats-optimize-query-performance",
          "https://techcrunch.com/2025/10/10/spyware-maker-nso-group-confirms-acquisition-by-us-investors/"
        "评论链接": [
          "https://news.ycombinator.com/item?id=45553577",
          "https://news.ycombinator.com/item?id=45555308",
          "https://news.ycombinator.com/item?id=45504540",
          "https://news.ycombinator.com/item?id=45553995",
          "https://news.ycombinator.com/item?id=45555873",
          "https://news.ycombinator.com/item?id=45523370",
          "https://news.ycombinator.com/item?id=45556474",
          "https://news.ycombinator.com/item?id=45555012",
          "https://news.ycombinator.com/item?id=45553132",
          "https://news.ycombinator.com/item?id=45551260",
          "https://news.ycombinator.com/item?id=45553783",
          "https://news.ycombinator.com/item?id=45506055",
          "https://news.ycombinator.com/item?id=45520585",
          "https://news.ycombinator.com/item?id=45553701",
          "https://news.ycombinator.com/item?id=45552049",
          "https://news.ycombinator.com/item?id=45551504",
          "https://news.ycombinator.com/item?id=45553422",
          "https://news.ycombinator.com/item?id=45489497",
          "https://news.ycombinator.com/item?id=45553835",
          "https://news.ycombinator.com/item?id=45547359",
          "https://news.ycombinator.com/item?id=45555523",
          "https://news.ycombinator.com/item?id=45547344",
          "https://news.ycombinator.com/item?id=45553764",
          "https://news.ycombinator.com/item?id=45547566",
          "https://news.ycombinator.com/item?id=45498055",
          "https://news.ycombinator.com/item?id=45506748",
          "https://news.ycombinator.com/item?id=45515842",
          "https://news.ycombinator.com/item?id=45549434",
          "https://news.ycombinator.com/item?id=45516964",
          "https://news.ycombinator.com/item?id=45555570"
        "北京发布时间": [
          "2025-10-12 07:16:05",
          "2025-10-12 12:46:57",
          "2025-10-07 23:40:09",
          "2025-10-12 08:22:15",
          "2025-10-12 14:46:58",
          "2025-10-09 12:06:43",
          "2025-10-12 16:37:01",
          "2025-10-12 11:41:29",
          "2025-10-12 06:16:18",
          "2025-10-12 02:06:40",
          "2025-10-12 07:43:42",
          "2025-10-08 01:26:20",
          "2025-10-09 04:58:37",
          "2025-10-12 07:32:25",
          "2025-10-12 03:41:27",
          "2025-10-12 02:36:51",
          "2025-10-12 06:58:30",
          "2025-10-06 17:36:08",
          "2025-10-12 07:53:17",
          "2025-10-11 15:32:08",
          "2025-10-12 13:31:00",
          "2025-10-11 15:29:23",
          "2025-10-12 07:41:00",
          "2025-10-11 16:27:26",
          "2025-10-07 08:40:26",
          "2025-10-08 02:19:37",
          "2025-10-08 21:18:25",
          "2025-10-11 22:31:15",
          "2025-10-08 23:01:06",
          "2025-10-12 13:39:22"
  "meta": {
    "instanceId": "4c3a751e7d3935ecf344bab5378e53107b88fe3e154ce293c458a770a6ca1bdd"
  • **n8n version:**1.114.4
  • **Database (default: SQLite):**sqlite
  • n8n EXECUTIONS_PROCESS setting (default: own, main):own
  • Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
  • Operating system:Mac OS Sequoia 15.6.1
I see that you are trying to scrape a webpage in the last step of the workflow. Common reason that you are getting this issue is then the **website you’re trying to scrape is actively blocking automated requests(python scripts).
Some of the ways to tackle is:
  • Using an agent (you’ve tried it already)
  • Using an API like WebScraper API including premium=’true’ rather than using a bot like beautiful soup will work if the website is cloudfare protected.
