Problem in node ‘Render Final Video‘
Error continues to occur despite checking credentials. In my Creatomate nodule it keeps getting stuck.
" Problem in node ‘Render Final Video‘
Authorization failed - please check your credentials"
That is the error that is presented.
Additional error message:
401 - "{"hint":"The provided API key is invalid.","documentation":"https://creatomate.com/docs/authentication\“}”
Hey @Joe_Camarata,
The service you are using is saying the API key is invalid, Can you make sure the key is correctly set. If you continue to run into issues it may be worth reaching out to the service you are using to see if they know why your key is invalid.
