However, I tried adding each RSS feed individually in the URL field, including copying & pasting the one that’s shown in the image above with the error message, and they all work as they should.
NodeOperationError: Non-whitespace before first tag. Line: 0 Column: 1 Char: at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/RssFeedRead/RssFeedRead.node.js:106:27) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:741:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:724:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1155:20
It looks like the error is coming from the 3rd item in your Google Sheet, I suspect the XML data being returned is invalid. Can you share what the first 5 urls are in your google sheet so we can test them?
For now to work around this the best option would be to set the RSS Node to use the error output branch that way you can continue with the rest of the workflow and see which urls are failing.
Thanks so much - I double-checked every single item again and it looks like one of the feeds didn’t function correctly!
I’m happy to report back that removing this one resolved the issue
Follow up question if I may:
I want to retrieve new items from a number of RSS feeds, every X hours
Setting a trigger to run every X hours, then pulling the feed URLs from the Google Sheet, and then using the RSS read seems to be the most elegant solution (with the fewest nodes/ triggers used)
However, using the RSS Feed Trigger, one for each RSS Feed, seems to be the more robust one (especially since it’s already build in to check only for new items)
Do I assume correctly that the second version with the RSS Feed Trigger would actually be the better version? (since I could then all link them to the same next node…)
