this is the full error message
ERROR: field.reduce is not a function
Details
Stack
TypeError: field.reduce is not a function
at formatResult (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Splunk/GenericFunctions.ts:196:15)
at formatResults (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Splunk/GenericFunctions.ts:208:6)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at Object.execute (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Splunk/Splunk.node.ts:355:22)
at Workflow.runNode (/usr/lib/node_modules/n8n/node_modules/n8n-workflow/src/Workflow.ts:1263:19)
at /usr/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:951:29
