Hi @Rad, sorry for the problem and glad to hear you could narrow this down to the file size. Can you confirm if your n8n instance ran out of memory here and possibly crashed? Any indicators in the server logs?
Not sure yet, you’re right, I will investigate the logs and see if there is anything to get, it would be great to expose these logs somehow in the UI thgouh the workflow execution history, this way users find them handy, but yes I will take a deeper look and see if the memory is an issue. Running this through docker so am not sure if this might be the cause. I will update you here
