I recently installed N8N on a server using Docker with an N8N image that uses Traefik labels. I also configured the domain of my project in the .env file.
However, I’m having an issue with the reverse proxy that blocks the process when I try to run my workflow using the DNS. Yet, using the IP address with full network access, I can run the workflow normally.
I’m using version 0.219.0 of N8N with Postgresql 11 and Mongo 4.4. Has anyone encountered a similar issue in N8N? If so, how did you solve this problem?
n8n 0.219.0
Database you’re using PostgreSQL 11):
Running n8n with the execution process [own(default), main]:own
Running n8n via [Docker, npm, n8n.cloud, desktop app]:Docker
This behaviour could suggest a problem with the reverse proxy (or possibly load balancer and other network components) you have in use. Would that be just Traefik or do any other components sit between n8n and your browser?
When I launch the application using the IP, the process ends correctly without any errors. However, when I use the DNS, sometimes it starts and stops at the end of the node by endlessly pushing the session ID, and sometimes it never starts, but the logs show that it’s working in the background even though the UI is blocked.
Are there any other flows to add on the reverse proxy side besides the 5678 input port and the telemetery?
Hi @Micka_Rakotomalala, suspect the problem isn’t so much with the DNS as with one of the network components between n8n and your browser. n8n uses Server-Sent Events (SSE) to communicate with the UI which one of the components appear to be blocking. A working example config for nginx can be found here, but there might be more in your setup preventing these from working.
Also, seeing you already have nginx in place as shown on your architecture graph you wouldn’t need to use Traefik with n8n (and could remove this bit of additional complexity).
Lastly, we added support for WebSocket as an alternative to SSE recently which you could test if you’re having trouble with SSE. To do so, you’d need to set the N8N_PUSH_BACKENDenvironment variable to websocket.
I removed in the docker-compose the traefik service, add the N8N_PUSH_BACKEND in the environment. And also configured the reverse proxy on the ngnix side with “upgrade”, and it’s fixed. Thanks a lot.
