How can i solve this problem ? is there any way i send encryption key so it wont be change frequently?
Problem loading credential
Credentials could not be decrypted. The likely reason is that a different “encryptionKey” was used to encrypt the data.
Hey @Ibrahim_Jogilkar,
Welcome to the community ![]()
It sounds like you have not installed n8n correctly, Can you make sure you have the docker volume set so that the data in /home/node/.n8n is not replaced. If you are not able to do that you will need to set the N8N_ENCRYPTION_KEY environment variable.
For the credentials you already have if you don’t know the encryption key you will need to make them again.
